This command sets the narrow metric for one or all IS-IS VLANs.
| vlan all | Applies the configuration to all IS-IS VLANs. |
| vlan_name | Specifies a single VLAN to which the configuration applies. |
| metric metric | Sets the metric value. The range is 1 to 63. |
| level [1 | 2] | Limits the configuration to either level 1 or level 2. If neither level 1 nor level 2 is specified, the configuration applies to both levels. |
10.
If narrow metrics are enabled, this value is used in the associated LSPs for the selected VLANs.
The following command sets the narrow metric for all IS-IS VLANs to 15:
configure isis vlan all metric 15
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
